1 Reply
- BoonT_Intel
Have you attempt the read back the command_config register from the MAC and see it configure correctly? Especially the RX_ENA bit 1 is set to 1?
I will recommend you generate the example design and run the simulation. the compare the traffic pattern waveform between your design with the example design.
