How to configure Dual Compressed Images on MAX10 without IP core?
- 1 year ago
Hi there,
What you are encountering now seems to be a config issue. It looks like the previous problem with sof -> pof conversion has been resolved. Unfortunately, the root cause of the failure is still unclear. So I would like to further confirm the following:
- Loading the standalone sof file included in the pof works fine, right?
- In step 6, the CPF mode is set to Internal Configuration.
- Does the Programmer show any specific error messages?
- If you reduce the JTAG speed to 6 MHz in the Programmer, does it help to resolve the issue?
WZ
Make sure you set Generate Compressed Bitstreams in the Device & Pin Options.
In the Programmer, are you choosing to program CFM0 and CFM1, not the UFM?
Maybe check out this training: https://learning.intel.com/Developer/learn/courses/341/remote-system-upgrade-in-intelr-maxr-10-devices
- NTA1 year ago
I have set both projects to compressed:
Assignments -> Device -> Device and Pin Options... -> Configuration
- Configuration Scheme: Internal Configuration
- Configuration Mode: Dual Compressed Images (512Kbits UFM)And I have also selected CFM0 and CFM1 in the programmer.
Thank you for the link!
I will definitely take a look at the training, even though it seems to go far beyond what we are trying to achieve.
