dnortm
7 years agoHow to configure AS flash on development board (Cyclone 10 GX)
Hello everyone,
I'm struggling with the persistent configuration of the Cyclone 10 GX development board. Usually I only work with sof files (directly load into SRAM), but now I have an application that should automatically start with power-on. I already tried to convert the sof file to a jif file, and loaded a design with the Serial Flash Loader IP, but I'm stuck if this is the right way to go. Do you have some guides for this use case?
Thanks in advance,
Dominik
1 Reply
- Vicky1
Hi Dominik,
Could you please elaborate a bit more about "but I'm stuck if this is the right way to go"?
- Are you able to auto detect device/cable issue
- Check Setting up the Development Kit & Default Switch and Jumper Settings from link below,
- Refer the link below for SFL IP,.jic file & programming the serial configuration device using .jic ,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an370.pdf
If you have any concern,please let me know,
Vikas Jathar
