dnortm
7 years agoHow to configure AS flash on development board (Cyclone 10 GX)
Hello everyone, I'm struggling with the persistent configuration of the Cyclone 10 GX development board. Usually I only work with sof files (directly load into SRAM), but now I have an application t...
Vicky1
7 years agoHi Dominik,
Could you please elaborate a bit more about "but I'm stuck if this is the right way to go"?
- Are you able to auto detect device/cable issue
- Check Setting up the Development Kit & Default Switch and Jumper Settings from link below,
- Refer the link below for SFL IP,.jic file & programming the serial configuration device using .jic ,
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an370.pdf
If you have any concern,please let me know,
Vikas Jathar
