13 years agoIt depends a lot on the type of file which you want to compile. If it is a megacore or IPcore file which requires license, then I doubt if it will work. But for normal files i think it should be possible. But you can copy the required quartus library from c:/altera/<version>/quartus/eda/simlib (hope, i got it right) and give a try at your dept server.
Cheers, manihatn
