How to combine separate IP simulation scripts into one, ip-setup-simulation
- 5 years ago
Hi @TSchu3
You may refer to the User Guide(UG) below to check the simulation flow.
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-20093.pdf
For example, have you specify the EDA Tool in the Settings, have you run compilation before generate simulation script.
You may test out the design example in the UG to learn how it works.
Richard Tan
Hi @TSchu3
Richard Tan
Thanks! this is what I needed. I was skipping the compilation step since my design is not finalized. I just wanted to generate the IP and pull it into my simulation. But the compilation is needed before the 'generate simulator Setup Script for IP' tool will work.
