16 years agoThank you so much all! Since I just want to perform simulation (for smaller sets), I will use the virtual pins to perform simulation.
However, for the high-level, I will use the method suggested by KAZ where only 16-bit for real and 16-bit for imag are use. And the 128 inputs take turns to input to the device. But, why even I have assigned all the I/O pins as virtual pins, the message of 'can't place pins due to device constraints' still pop up? Any suggestions? I have checked with the Pin Planner and all the I/O pins gone. So, I am quite sure I have assigned the virtual pins properly.
