16 years agoThanks. Yes, I splits the FFT up into smaller sets (the butterfly computation). And each of these smaller sets, I write a VHDL code and treat it as a component and call it in my high-level design. What if I am writing a low-level VHDL code (which I will use it as a component of my FFT) and it has many I/P ports, and I would like to perform a small simulation? Should I also use the way you mentioned?
One more last question: If say I am using 128-point FFT. Is it the 128 real and imaginary inputs will take turn to input to the device using 16 bits real and 16 bits imag input pins?
