16 years agoFor example, I have a simple code:
Library ieee; use ieee.std_logic_1164.all; use ieee.std_logic_arith.all; use ieee.std_logic_unsigned.all; entity orgate2 is port( out1 : out std_logic_vector(3 downto 0) ); end orgate2; architecture add of orgate2 is signal temp : std_logic_vector (3 downto 0); begin temp <= "1111"; out1 <= temp - "1100"; end add; I want to check the signal temp. Then, I go to node finder and select design entry (all names). On the list, I have selected the node temp. Now, the temp node is on my waveform list and I would like to perform simulation. However, when I performed the simulation, the temp node no longer exist and gone. Anyone can help?
