11 years agoYou can change the directory where the output files go by going to Assignments->Settings and selecting Compilation Process Settings on the left. Under Save project output files in specified directory, change Directory name: as needed (default is output_files). You need a separate directory for all the output files because your changed settings will probably make changes to several intermediate files before the final sof file is generated.
