How to change Qsys file displaying size on Quartus 13.0 Lite edition
Do you mean the software interface or the font size? if it is software interface issue, you can try to enlarge the display by click the highlighted button below.
Joanne
- cosx7 years ago
Hi Joanne,
thank you very much for your reply.
I think it should be the font size issue. As you can see the image above, all words are intolerably small.
My software version is 13.0, so it may not have the setting you mentioned.
Thanks anyway!
Mingqiang
- JoanneSinY_L_Intel7 years ago
I am not sure is that any environment variable can modify the font size.
But my suggestion is to download the version 18.1
http://fpgasoftware.intel.com/?edition=lite
Joanne
- cosx7 years ago
thank you for your help!
I had downloaded quartus 18.1 edition before downloading the 13.0 edition.
I need the 13.0 because it needs to support DE0 series board.
If you know how can 18.1 edition supports the Cyclone III family, I will appreciate.
Otherwise I have to stick on 13.0 version.
Thanks!
Mingqiang
- cosx7 years ago
Hi there,
I just solved the problem by downloading 13.1 version.
Thank you for your help!
Best Wishes,
Mingqiang
