16 years ago --- Quote Start --- Hello GPK, great idea, thanks a lot. However, I tried different setting combinations of 'Show X on timing violations' and 'Setup and hold time violation', but none has worked in the Modelsim run. Does anyone know how to disable this check directly in the Modelsim environment? Thank you. --- Quote End --- Hi, as far as I know there is a verilog command line option called "+notimingchecks". Maybe you can look in the modelsim help :rolleyes: Kind regards GPK
