Yamada1
3 years agoHow to avoid the "Estimated Delay Added for Hold Timing" grant
Previously, when I asked a question about "Estimated Delay Added for Hold Timing", I was told that there are two ways to avoid it being given: "Compiler Settings" to set the whole setting and "Assign...
- 3 years ago
Hi Yamada,
From my experience, there is only one way to to do which is fitter setting as you mentioned. Regarding the assignment seem there is no information documented for that. With first option did you able to resolve the hold timing?
IntelSupport
Contributor
3 years agoI assume the individual assignment is probably sdc constraint set input delay for setup and hold.
