How to avoid the "Estimated Delay Added for Hold Timing" grant
- 3 years ago
Hi Yamada,
From my experience, there is only one way to to do which is fitter setting as you mentioned. Regarding the assignment seem there is no information documented for that. With first option did you able to resolve the hold timing?
Thank you for answering.
I understand that "Estimated Delay Added for Hold Timing" can only be set to the whole with "Compiler Settings".
It was very helpful.
In addition, I do not try the settings yet.
The reason for the compilation was not for hold constraints, but for setup.
The fact that "Estimated Delay Added for Hold Timing" is added to the hold to satisfy the hold means pressure on the setup side.
If you cancel it as an overall setting here, there is a possibility that the hold in other parts will occur.
I'm going to consider if other approaches are possible.
