12 years ago
How to avoid register "optimisation" in DSP
Hello everyone,
I can't seem to solve this by my own:
I'm using multipliers in my code, as you might know, on Stratix4 getting out of a DSP block has a timing cost of ~0.350ns
So, I'm willing to spend 1 clock cycle to go out of a DSP block, BUT the synthesis aggressively wants to locate any register that I place after inside the DSP. Instanciating explicitely the alt_multadd module or lpm_mult does not change anything.
The only way I found to avoid that is to place 2 "wasted" registers after, thus exhausting the register resources of any DSP slice, but that is ugly and only show that I don't know how to properly constrain my synthesis.
Setting the following attributes does not change anything:
preserve
keep
So, do you know of any assignment, or directive to "protect" my general register from this effect ?
BTW what is this effect? (register merging, dsp balancing?)
    ok, the syntax is good, because that:
    attribute altera_attribute of p1_x : signal is "-name auto_packed_registers ""MINIMIZE AREA""";
    works.
    There seems to be a problem with "MINIMIZE AREA WITH CHAINS".
    anyway, regardless of that minor bug, all HDL assignments are joyfully ignored...
    try this:
    attribute altera_attribute of p1_x : signal is "-name auto_packed_registers MINIMIZE AREA WITH CHAINS";
    This time I can contribute some usefull tric, the right assignment syntax is:
    attribute altera_attribute of p1_x : signal is "-name AUTO_PACKED_REGISTERS_STRATIXII ""MINIMIZE AREA WITH CHAINS""";
    Even if the target is STRATIXIV....
    (copied exactly from the .qsf file)
