9 years ago
How to avoid delay
Hello everyone,
My problem is that i have an output available at a current clock cycle and i need to be read at the same clock cycle by another register.
My top level entity is where i instantiate components but the problem is exactly in this code :
library ieee;use ieee.std_logic_1164.all;
use ieee.numeric_std.all;
use ieee.std_logic_signed.all;
use ieee.math_real.all;
library std;
use work.MIN.all;
entity labeling is
generic(
        LABEL_WIDTH : integer;
        PIX_WIDTH : integer );
   port(
       clk_proc : in std_logic;
        reset_n : in std_logic;
        ------------------------- in flow -----------------------
        in_data : in std_logic;
        in_fv : in std_logic;
        in_dv : in std_logic;
        p00u : in std_logic;
       p01u : in std_logic;
       p02u : in std_logic;
       p10u : in std_logic;
       p11u : in std_logic;
       p12u : in std_logic;
        ------------------------ out flow -----------------------
        out_fv : out std_logic;
        out_dv : out std_logic;
        ------------------------ labels --------------------------
      north_LABEL , west_LABEL : in std_logic_vector ((LABEL_WIDTH-1) downto 0);
        north_west_LABEL , north_ouest_LABEL : in std_logic_vector ((LABEL_WIDTH-1) downto 0 );
        current_LABEL , Label_to_merge , Label_instead : out std_logic_vector ((LABEL_WIDTH - 1) downto 0);
        need_to_merge, need_to_resolve: out std_logic ;
        number_of_object : out natural
end labeling;
architecture arch of labeling is
------ ------------------signaux pour les étiquettes-------------------------------------------------------------------------------
signal north ,west : integer :=0;
signal north_ouest , north_west : integer:=0;
signal curr : integer;
signal L_to_merge , L_instead : integer:=0 ;
signal merge , resolve : std_logic;
Begin
    north <= to_integer ( signed( '0' & (north_LABEL)));
    west <= to_integer ( signed( '0' & (west_LABEL)));
    north_west <= to_integer ( signed( '0' & (north_west_LABEL)));
    north_ouest <= to_integer ( signed( '0' & (north_ouest_LABEL)));
-------------------------------------- labeling---------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------------
    process(clk_proc,reset_n)
        variable new_label : integer:= 1 ;
        variable n_objects : integer := 0 ;
        begin
            if (reset_n = '1' )then curr <=0;
            elsif (rising_edge(clk_proc))then
                if ((in_fv and in_dv )='1' ) then
                   if (in_data= '0')then
                        curr <= 0;
                        merge<='0';
                    else
                        if (p01u = '1') then
                            curr <= north;
                            merge<='0';
                        else
                            if (p02u='1') then
                                if (p00u ='1') then
                                    merge <='1';
                                    curr<= minimum(north_west,north_ouest);
                                    L_to_merge <= maximum (north_west,north_ouest);
                                    L_instead <= minimum(north_west,north_ouest);
                                else
                                    if (p10u ='1') then
                                        merge <='1';
                                        curr<= minimum(west,north_ouest);
                                        L_to_merge <= maximum(west,north_ouest);
                                        n_objects := n_objects - 1 ;
                                    else
                                        curr<= north_ouest;
                                        merge<='0';
                                    end if;
                                end if;
                            else
                                if (p00u ='1') then
                                    curr <= north_west;
                                    merge<='0';
                                else
                                    if (p10u ='1') then
                                        curr<= west;
                                        merge<='0';
                                    else
                                        curr<= new_label;
                                        new_label:= new_label+1;
                                        n_objects := n_objects + 1 ;
                                        merge<='0';
                                    end if;
                                end if;
                            end if;
                        end if;
                    end if;
                    if (merge='1' and north_ouest=minimum(north_west,north_ouest)) then
                                        resolve<='1';
                    else
                                        resolve<='0';
                    end if;
                    if merge='1' then
                    end if;
                end if;
            end if;
     report "The number of objects is " & integer'image(n_objects);
     number_of_object<=n_objects;
    end process;
current_LABEL <= std_logic_vector(to_signed(curr,LABEL_WIDTH));
Label_to_merge<= std_logic_vector(to_signed(L_to_merge,LabEL_WIDTH));
Label_instead<= std_logic_vector(to_signed(L_instead,LabEL_WIDTH));
need_to_merge<=merge;
need_to_resolve<= '1' when merge='1' else
                        '0';
end arch;
Where the signal current_LABEL takes always the previous values of North, North_ouest, North_est and west instead of the current values .
Ps: The North, North_ouest, North_Est and West values are provided by another module.
    FPGAs are good at parrellel logic. If you need Lx at different places, then create copies of it.
