FMaxi
7 years agoHow to auto-convert SOF to JIC after compilation using TCL script (solved)
I've added following line to redirector.qsf (redirector is project name) set_global_assignment -name POST_FLOW_SCRIPT_FILE "quartus_sh:sof_to_jic.tcl" Contents of sof_to_jic.tcl: exec quartus_c...
FMaxi
7 years ago@JohnT_Intel, thanks again. I've accidentaly found the answer to question that can relate my problem.
I had problems with CONF_DONE on one of my boards. Simply programming of FPGA ended failure. That's why I had to "Disable CONF_DONE check". Maybe I wouldn't have to disable CONF_DONE check if I change the PLC option!
