How to add top level generic into a Qsys system?
Thanks lot for your clarification. As I understand it, you would like Qsys to be able to allow setting/exporting of subcomponent generics up to the qsys_system level. This is so that when you instantiate the qsys_system as a submodule to another top level, you are able to pass the generics from top level to qsys_system and down to the Qsys sub component.
If my understanding is correct, as I discussed with my peers, it seems like currently this is something not supported by Qsys. As a workaround, you might need to manually edit the qsys_system.vhd file to export the generics. Sorry for the inconvenience. I will look into filing enhancement on this for future software release.
Chee Pin
