gyuunyuu
Contributor
7 years agoHow to add top level generic into a Qsys system?
Some custom VHDL components in my Qsys system have test modes. These are controlled via generics on their top level. These components are currently in a Qsys system. In Qsys, I can click on them and ...
CheepinC_altera
7 years agoHi,
My understanding is that the Qsys generated top level .vhd file should have the generics. I might be wrong. Would you mind to share with me your .qsys file so that I could replicate the observation? I might need to further engage with Factory in case there are generics in the Qsys system but the generated top level .vhd file does not have it.
I believe the workaround currently would be as you mentioned, manually add them in the Qsys generated top level .vhd file while we are looking into it to avoid gating your progress.
Thank you.
