14 years ago --- Quote Start --- I think I found the answer. The problem is that there are two ISP1362's out there. wtfe's solution will work if you use the ISP1362_CTRL.v (available on alterawiki). wtfe's solution will not work with the ISP1362_IF.v provided by Terasic. Use ISP1362_CTRL.v from alterawiki, then follow wtfe's solution. --- Quote End --- HI willbable, thanks... i has been try your suggestion to used ISP1362_CTRL.v as u recommend available on alterawiki....and finally i can generate that file onto SOPC....... However.... after it generated the result mentions as below????? Why.....????plz somebody help me ...it urgent....and i appreciated it..... ERROR: slave (ISP1362/avalon_slave_1) data width is 0 Error: Generator program for module 'cpu_0' did NOT run successfully.
