14 years agoI think I found the answer.
The problem is that there are two ISP1362's out there. wtfe's solution will work if you use the ISP1362_CTRL.v (available on alterawiki). wtfe's solution will not work with the ISP1362_IF.v provided by Terasic. Use ISP1362_CTRL.v from alterawiki, then follow wtfe's solution.
