18 years agoThere is no automatic conversion from *.hex to *.mif, as far as I know. If you want an externally created hex file to be compiled into your design, you must specify *.hex instead of *.mif in Megafunction instance. Quartus is supporting both formats. You have to use also *.hex memory images when simulating with ModelSim, cause ModelSim needs *.hex input.
