Altera_ForumHonored Contributor18 years agohow to add hex file into design file to compile I'm using Quartus II version 7.2, a few issues I'm stuck on. I have a design file and a hex file that was generated from the asm codes (these files are handed down, I did not create them). In the d...Show More
Altera_ForumHonored Contributor18 years agoI've had luck putting the hex files in the project's working directory.
Recent DiscussionsHow to fix Error(23782): Failed to find an expected reportMailbox Client IP - SEND_CERTIFICATE command through FPGA fabricQuartus Prime license rehosted, unable to runFailed to run ip-setup-simulation:Connection bit order between hierarchy
