18 years ago --- Quote Start --- Could it be that the hex file name is not matching the name that is hard code somewhere in the HDL file? --- Quote End --- I'm still guessing how you referenced the hex file in your design (or "hard coded" it). Can you please clarify. If it is e. g. referenced in a RAM or ROM Megafunction instance and not found during compilation (because of wrong filename or whatever), then you get a clear and understandable warning in compilation report. It would not be necessary to count bytes to check for.
