18 years agoHello,
the only possible usage of hex files I'm aware of, would be to initialize a ROM or RAM in FPGA internal memory. Could be instructions for a small software processor or tables used in calculation. This would be achieved by referencing the files in respective memory Megafunctions. If you are intending something different, you should clarify. Regards, Frank
