16 years agoSimply assume, that the timing analyzer gets sufficient information about the PLL clocks from the PLL parameters (you can check this in the timing analyzer report). The problem is in the design itself, not the clock. You have to check the timing analyzer report in detail to understand the nature of the timing violation, e.g. if it's caused by a signal crossing the clock domains or if it's within a clock domain.
