18 years agoDo you mean that if I check out:
--- Quote Start --- Assignment->Settings->Fitter Settings and make sure "Optimize hold timing" is set to "All paths". This will allow the fitter to add the data delay you need. You may also want to turn on "Optimize fast-corner timing. --- Quote End --- Then the fitter will add delay when necessary, so that hold violation will never occur?
