11 years agoHow to access On Chip Memory in VHDL
Hi guys, I have the Problem, that i cant access On Chip Memory. I´m using a DE0-Nano Board, with a Cyclone IV EP4CE22F17C6 FPGA. I have generated the Memory with Qsys: http://abload.de/th...
11 years agoApparently you made a modification to your post that triggered the forum's antispam system. I've approved your post and it should now appear.
As for your problem I don't see anything wrong at first glance, except that you don't generate or use any reset signal, which is bad practise. Still it doesn't' explain your symptoms. Can you have a look at all the warnings written by the Quartus synthesizer when you compile? Especially messages about your .hex file being not found or in a bad format. Those usually generate only warnings and not errors.
