14 years agoHi Bharath
http://www.altera.com/literature/hb/...s_qii51015.pdf (http://www.altera.com/literature/hb/qts/qts_qii51015.pdf) You can see in the page No 25 for a clear description that whenever Quartus detects changes in the Top level file It re-compiles the sub modules also There is an option of setting the Rapid recompile to on, and make the net-list type of the partition that is changed to source manually Also there is another option described "Forcing Use of the Compilation Netlist When a Partition has Changed" by setting On the Advanced tab, "turn on the ignore changes in source files" But it was cautioned to be used by advanced users only
