How TimeQuest analyzes path though the latch?
I am sorry for the late response.
Timing Analyzer found latches across multiple look-up tables (LUTs), or latches that do not include an enable (e.g. SR latches). The Timing Analyzer does not support analyzing this latch implementation as a synchronous element, but treats these latches as a combinational loop.
It is recommended to design without the use of latches whenever possible. You have to implement these latches with registers using asynchronous load and data signals, or remove these latches from your design.
You may refer to Intel Quartus Prime Pro Deisgn Recommendation User Guide https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/ug/ug-qpp-design-recommendations.pdf (Chapter 1.5.3 Latches)
Please let me know if you have any questions.
