17 years agoI'm desperate for this problème
I don’t understand why the path doesn’t change with this procedure follow: In Timequest I measure the path with report path. I set in sdc file set_min_delay -from [get_pins {Fdata_un|regout}] -to [get_pins {Fdata_deux~reg0|datain}] 5.000 set_min_delay -from [get_registers {Fdata_un}] -to [get_registers {Fdata_deux~reg0}] 10.000 I write the new sdc file. I compile project with the sdc file Timequest is enable Sdc file is added to project Assignments -> Settings -> Fitter -> Optimize Hold Timing -> All Paths. Is set After the compilation I reopen timequest and measure the delay path. Any difference. Why???? Thank for you help
