14 years ago
how partition works
hi friends,
i am having doubt about partitions, how it works.
top_level.v
|sub_level1_a.v
| |sub_level2_a.v
| |sub_lelvel2_b.v
from the above hierarchy, if sub_level1_a.v only (not the sub_level2_a.v) partitioned for PAR and compiled.
now which code exactly reserved by the partition. sub_level2_a.v code is instantiated under sub_level1_a.v, so will it be also reserved by the partition, or only the logic statements which are written in the sub_level1_a.v code only gets partitioned?
later if i change sub_level2_a.v code then will it be re-routed as per new changes?
Thanks in advance
1 Reply
    --- Quote Start ---
    hi friends,
    top_level.v
    |sub_level1_a.v
    | |sub_level2_a.v
    | |sub_lelvel2_b.v
    Thanks in advance
    --- Quote End ---
    if you define a partition for sub_level1_a all code including the lower level blocks will be part of the partition.
    Best regards
    GPK
