10 years agoHow match two bus in one
Hi, I need match the two bus, to got 32 bits in the end
Isn't working, "12009 Node "Novo[x]" is missing source" Where's the problem? Thanks very much2 Replies
Dont join the wires - leave them disconnected but use named association (ie. name the two dangling ends the same name as the larger bus - named association)
--- Quote Start --- Dont join the wires - leave them disconnected but use named association (ie. name the two dangling ends the same name as the larger bus - named association) --- Quote End --- Thanks thanks thanks thanks Thanks a lot my friend
