Altera_ForumHonored Contributor13 years agoHow many Serdes channels in the EP2AGX260FF35C4N? For the Arria II GX device I’ve selected(EP2AGX260FF35C4N) the data sheet and the PinOut file(EP2AGX260.xls) indicates 16 serdes channels but in the Quartus II pin planner I can only assign 12 chann...Show More
Altera_ForumHonored Contributor13 years agoI'm using version 11.0. Yes I have a SR filed. I'll try upgrading to 11.1. Thanks Avatar
Recent DiscussionsAutomatically added negative node for TDS output doesn't work with Agilex 5Design Space Explorer - *** Fatal Error: Access Violation at 0X000000001E19EB30Tensor block usageError (169008): Can't turn on open-drain option for differential I/O pin HPS_DDR3_DQS_N[1]Highlight similar instances of a selected word fails when scrollingSolved
