10 years agoHow is memory synthesized by quartus ii ?
I am using a cyclone ii device (ALTERA DE1 Board by TERASIC) for implementing an application. My application requires approximately 100KB of RAM. I referred to the device datasheet and it says...
10 years ago --- Quote Start --- The tool will be converting this into logic elements. Is this correct?? --- Quote End --- In page 11 in the paper I referred earlier (my apologies for referring to an older paper). There are different ways a memory is implemented this can be using dedicated RAM blocks, logic cells etc. By default the fitter selects what it thinks is the best way to fit your design. You can use for example the Assignment Editor to specify if it should use a specific location.
