10 years agoHow is memory synthesized by quartus ii ?
I am using a cyclone ii device (ALTERA DE1 Board by TERASIC) for implementing an application. My application requires approximately 100KB of RAM. I referred to the device datasheet and it says...
10 years ago --- Quote Start --- From the examples which you have shown, it seems that the tool will synthesize the code by using RAM blocks if I write something like: module ram_single(q, a, d, we, clk); output[7:0] q; input [7:0] d; input [6:0] a; input we, clk; reg [7:0] mem [127:0]; always @(posedge clk) begin if (we) mem[a] <= d; q <= mem[a]; endendmodule And If I write something like reg [63:0] mem[4095:0]; The tool will be converting this into logic elements. Is this correct?? --- Quote End --- Its not really to do with the size of the array, more to do with how you access it. As long as the code is synchronous and follows the ram tamplates: https://www.altera.co.jp/ja_jp/pdfs/literature/hb/qts/qts_qii51007.pdf It should infer one large ram (which underneath is made up of lots of smaller rams).
