8 years agoHow does the checksum in the map file relates to the checksum o fthe rpd file?
Hello, I'm working on a remote upgrade feature through Ethernet for a MAX 10 device. In order to make sure that the content of the rpd file matches the configuration, I intend to read the map fi...
MYild1
7 years agoHi did you found a solution, I m in the same situation
