10 years agoHow does one verify the SDC constraints?
When one writes VHDL it is possible to use testbench to determine if the code functions as intended, with C/C++ program one can also use test cases. How does one verify timing constraints? How does o...
10 years agoAfter some bad experiences with temperature dependent timing bugs we started to do full temperature cycle test over a limited (not full) industrial temperature range for each firmware release. When it fails you know you probably have a bug in the SDC constraints. Unfortunately when it passes you only know that this specific firmware build works on this specific board. We have not yet reached a confidence level in our SDC files that we can skip the temperature tests once a release passes. We had a case where small internal changes on a previously successfully tested design passed the STA but failed the temperature test. Temperature testing each release is expensive but still magnitudes cheaper than discovering it in the field.
