10 years agoHow does one verify the SDC constraints?
When one writes VHDL it is possible to use testbench to determine if the code functions as intended, with C/C++ program one can also use test cases. How does one verify timing constraints? How does o...
10 years agoOne simple thing I do to "verify" timing constraints is to constrain the design in a way that I know WON'T meet timing (for example, set an input or output delay to a value that can't possibly be met). Then constrain the design in a way that can easily be met. In each case TimeQuest should indicate a pass or fail condition. If it doesn't, you know something is amiss. This won't catch everything, of course, but I've uncovered a number of errors this way, including errors in my own thinking about how a particular timing constraint works.
