How do you access live data from an Altera MAX 10 FPGA's built in ADC as a block diagram within Quartus?
Are you looking for ADC data for post processing?
Please check below link
https://www.youtube.com/watch?v=u7y5ZR1E8SU
I can't seem to understand how to get the live 12-bit digital data of the analog signal. How can I access these bits using a block diagram for example?
>>You can get access to ADC digital data by using some logic. use IP's or custom IP.
Do I need to send a specific command to the ADC in order to start reading data?
>> No,
Let me know if you need any further assistance.
Anand
- PRiva17 years ago
Thanks so much for the response.
I have looked at that video and am very confused by it because it says to code a sequencer block at 3:59, but I'm assuming I should be able to get the ADC up and running without doing this?
This is where I am at:
I've verified that my ADC works because I've attached my .sof file to the System Console - ADC Toolkit (Beta) 0 and I can see the Oscilloscope react to my analog signal changes. Now I want to take that ADC and use it in a simple block diagram attached to some LEDs (or find a way to test it using signal tap). In QSYS, I expect that I should export "response" as this is where my data is located? I seem to get no data in this response though.
My ADC works perfectly in the System Console, how can I just get this data as 12 wires in a block diagram?
- AnandRaj_S_Intel7 years ago
Sorry for the delay,
You can access 12-bit ADC data with help of NIos II and PIO IP's with software help.
With the help of Niso ii you can read the ADC data and put it on to PIO.
When you create the system with above IP's you can see the bdf with 12-bit data out.
Refer below link for the example.
https://fpgacloud.intel.com/devstore/platform/16.0.0/Standard/adc-data-capture-with-nios-ii-processor/
Anand
