10 years agoHow do I use N25Q512 Quad-SPI Flash, instead of ECPQ512?
I have a board designed to boot the Cyclone V FPGA from AS Flash, using a N25Q512A13G1240E chip instead of Altera's EPCQ512. (NB: This is a product, not a dev-kit)
However, in Quartus Prime, the Programmer's "Convert Programming File" dialog only has the option of choosing EPCQ512 when generating the JIC file. When this JIC file is used to JTAG program the FLASH via the FPGA, it fails with the following message: "Error (209025): Can't recognize silicon ID for device 2. A device's silicon ID is different from its JTAG ID. Verify that all cables are securely connected, select a different device, or check the power on the target system. Make sure the device pins are connected and configured correctly." Presumably this is because Quartus reads back the ID of the N25Q512, and it doesn't match that of a EPCQ512. Any ideas of how to get around this? I think the Altera SoC Development board uses similar FLASH to mine, so presumably there must be some sort of work-around for this. NB: I am trying to configure the FPGA with this flash chip, not boot the ARM processor from it. (One step at a time!)30 Replies
I'm out of ideas on this as well. I have successfully programmed a micron 26Q256A quad spi chp on my SoCKit board. My previous posting is from my notes on how to do it. It may be that the programmer doesn't like the 512k version.
--- Quote Start --- I'm out of ideas on this as well. I have successfully programmed a micron 26Q256A quad spi chp on my SoCKit board. My previous posting is from my notes on how to do it. It may be that the programmer doesn't like the 512k version. --- Quote End --- It's not going to be my day (see attached Errata) - Altera_Forum
Bummer....
--- Quote Start --- It's not going to be my day (see attached Errata) --- Quote End --- I come back to this issue which can be interesting to me if I would like to replace and EPCQL by a SPI MICRON Flash. If the "ASx4 mode" is not supported by the EPCQ512, have you tried the "ASx1 mode" configuration ? If the PCB, hardware is designed to support the ASx4 it should work with the ASx1 configuration. In that case only one SPI Data line is used instead 4 and the configuraton time will be slower. - Altera_Forum
--- Quote Start --- I come back to this issue which can be interesting to me if I would like to replace and EPCQL by a SPI MICRON Flash. If the "ASx4 mode" is not supported by the EPCQ512, have you tried the "ASx1 mode" configuration ? If the PCB, hardware is designed to support the ASx4 it should work with the ASx1 configuration. In that case only one SPI Data line is used instead 4 and the configuraton time will be slower. --- Quote End --- Hi, Yes, I tried x1 mode with the N25Q512, but the Quartus Prime programming software wouldn't work as you can't select micron chips in that software. I can't discount their (also) being a problem with my custom hardware which is preventing this from working. I can't comment on whether the EPCQ512 would work in x1 mode as I don't have that chip fitted, but as that is an Altera chip then I would expect that workaround to work with the Altera software. As a slight aside, the new SoCrates II dev-board from EBV is listed as being fitted with N25Q256, so it will be interesting to see how they program those chips! If they are going to production with the N25Q256, then I would have though that you should be pretty safe using that chip too. (usual disclaimer apply!) Ref: http://www.ebv.com/products/product-details/9956/ The only difference I can see is that N25Q512 is a dual-die flash chip, whereas the N25Q256 is a single-die flash chip. This difference may or may-not be the reason why I can't program the N25Q512 on my board using the Quartus Prime programming software. I asked for technical support from Altera and they (using polite corporate language) told me and my company to get knotted. They just want everyone to carry on buying Altera EPCQ chips at 20x the cost of the Micron N25Q chips. For now I am trying to configure the FPGA from the SD-Card attached to the HPS side of the chip. (which is a different can of worms!) Time permitting I will write my own QSPI programming software and get to the bottom of why my N25Q512 won't work with the Quartus Prime programming software. This would download the configuration file (via a serial port) to a NIOS-II configured via JTAG. The NIOS-II would store the configuration file in SDRAM, then check the CRC, and then program that file into the N25Q512 using Micron's 'C' libraries. - Altera_Forum
There is an official partner program between MICRON and ALTERA : https://www.micron.com/solutions/micron-valued-partner-program/chipset-partner/altera
And if you look at the section "Download Micron Flash and DRAM support for Altera Platforms", the SPI NOR Flash N25Q is validated for Cyclone V. But I don' know what means "validated" : boot from MICRON FLASH or program FLASH also through Quartus tool.... - Altera_Forum
--- Quote Start --- There is an official partner program between MICRON and ALTERA : https://www.micron.com/solutions/micron-valued-partner-program/chipset-partner/altera And if you look at the section "Download Micron Flash and DRAM support for Altera Platforms", the SPI NOR Flash N25Q is validated for Cyclone V. But I don' know what means "validated" : boot from MICRON FLASH or program FLASH also through Quartus tool.... --- Quote End --- Yes, we fell for that marketing spin, and designed-in two Micron (BGA) flash chips (for FPGA and HSP boot), only to be told that Altera won't support programming them, won't help us debug the problem, won't confirm or deny whether there is a technical reason why the N25Q512 will or won't work with the Cyclone V. Then they just told us to go away and re-layout the board for EPCQ512 (SOIC) chips. Even if the EPCQ512 were available from any distributor the UK, they would still add £200 to the BOM and thereby make the product unsaleable. I no longer trust Altera. My direct experience is that unless your product is going to sell >100K units, you get no support and you are on your own. - Altera_Forum
Ouch! Thanks for the heads-up.
I'm facing similar problems trying to use a Macronix flash.
I found useful information in an app note by Cypress for their alternates. Google AN98558 and have a look at section 3.2 onwards. You may be able to program using nios2flash even though Quartus refuses to do the job. - Altera_Forum
--- Quote Start --- I'm facing similar problems trying to use a Macronix flash. I found useful information in an app note by Cypress for their alternates. Google AN98558 and have a look at section 3.2 onwards. You may be able to program using nios2flash even though Quartus refuses to do the job. --- Quote End --- Thanks, very interesting. I'll look into it.
