10 years agoHow do I use N25Q512 Quad-SPI Flash, instead of ECPQ512?
I have a board designed to boot the Cyclone V FPGA from AS Flash, using a N25Q512A13G1240E chip instead of Altera's EPCQ512. (NB: This is a product, not a dev-kit) However, in Quartus Prime, th...
8 years ago --- Quote Start --- For the ARRIA10 : 1 - I configure the FPGA with a design includng with an embedded "Serial Flash Controller" 2 - Once this is done, you should be able to detect the JTAG chain and then appear the ARRIA10 + EPCQL-512 in the Programmer 3 - Program the FLASH with the .jic file (Disable EPCS ID checked, Disable CONF_DONE checked) through the programmer : Quartus read the ID=0x20 (capacity of the FLASH=512M) I will try to attach a screenshot but I don' know how to do that for the moment.... --- Quote End --- I also think this way would be OK, I have tested it on Cyclone IV with N25q128
