How do I report powered-down transceivers and PLLs in Quartus Prime Standard?
HI,
The workaround should works as the power on calibration process and user triggered re-calibration process using dynamic reconfig is the same.
I presume you are not using PCIe. This workaround only works for none PCIe protocol.
You can refer to transceiver power-on calibration and user re-calibration guideline in below user guide doc (chapter 7.3, page 583)
- https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/hb/arria-10/ug_arria10_xcvr_phy.pdf
- You needs to reset both PLL and transceiver channel again after re-calibration is done
Another thing to mention is maybe you can use IOPLL instead of fPLL to provide the 100MHz clock to clkusr pin.
- Pls try your best to take care of the clock signal quality that maybe impacted by your board rework.
- I hope this rework is just temporary workaround while waiting for your board design fix in future.
dlim
Thanks Deshi. I'm trying to get a PLL (the 500Mhz TX fPLL) to recalibrate first, and having trouble. I'm still a little confused about a few things.
1) In what order do I reconfigure the PLLs and PMA? I have two fPLLs: 100M CDR ref clock, and 500M TX ref clock. Each of these has the pll_cal_busy asserted in signaltap, after I poweron. The avalon reconfig clock comes from an external 100MHz clock pin.
2) I don't see any reset signal explicitly on these PLLs. (Except for the avalon reset.) How do I reset each one?
3) The transceiver PMA remains in reset until the fPLLs are up and running. I have not tried to take the transceiver out of reset.
4) I tried to use a JTAG Avalon master to control the reconfig interface on the 500M TX PLL. I see the waitrequest asserted when I inspect the avalon bus in signaltap, but I can't seem to arbitrate for access. I tried to do an 8bit write of 0x2 to address 0x0 (and 32b write), but in both cases the avalon bus hung forever.
5) I see the fPLL has an option "Enable Altera Debug Master" which is also called NPDME, but I have not found how to use it. I do not have this enabled in the fPLL. Is this required to drive the reconfig_* interface with a JTAG Avalon Master?
Thanks again,
BryanH
