15 years agoNo worries, I copied the file into a new proc like so. Didn't know tcl was that easy :)
proc date2hdl {input_fn output_fn } {# Date2HDL version 0.1 HT-Lab 2003# # Useage: Date2HDL <input_filename> <output_filename># # Date2HDL will search for the string 'define/constant DATE_VECTOR_C and # replace the constant with the current date.# # VHDL (.vhd extention)# constant DATE_VECTOR_C : std_logic_vector(12 downto 0):="0000000000000";# Verilog (.v extention)# `define DATE_VECTOR_C 13'b0000000000000# # Date String format:# Day 0..31, 5 bits# Month 0..12, 4 bits# Year 0..15, 4 bits# Bit 12 11 10 09 08 07 06 05 04 03 02 01 00 # Format # # set to 1 to print debugging info
set debug 1
# Convert Decimal to Boolean String
proc dec2bool {decstring} {
switch $decstring {
00 {return "00000"}
01 {return "00001"}
02 {return "00010"}
03 {return "00011"}
04 {return "00100"}
05 {return "00101"}
06 {return "00110"}
07 {return "00111"}
08 {return "01000"}
09 {return "01001"}
10 {return "01010"}
11 {return "01011"}
12 {return "01100"}
13 {return "01101"}
14 {return "01110"}
15 {return "01111"}
16 {return "10000"}
17 {return "10001"}
18 {return "10010"}
19 {return "10011"}
20 {return "10100"}
21 {return "10101"}
22 {return "10110"}
23 {return "10111"}
24 {return "11000"}
25 {return "11001"}
26 {return "11010"}
27 {return "11011"}
28 {return "11100"}
29 {return "11101"}
30 {return "11110"}
31 {return "11111"}
default {
puts "Error in dec2bool proc, can't convert $decstring"
# exit
puts "Date2HDL version 0.1 WWW.HT-LAB.COM"
# Check number of argments# if {!=2} {# puts "Useage : Date2HDL <source_filename> <destination_filename>"# puts "Example: Date2HDL top.vhd top_date.vhd"# puts "Example: Date2HDL main.v mainsynth.v"# exit# }
# Check for HDL type
if { == 0} {
set hdl_type "Verilog"
set search_string {\s*`define\s*DATE_VECTOR_C}
} else {
set hdl_type "VHDL"
set search_string {\s*constant\s*DATE_VECTOR_C}
if {$debug} { puts "HDL Type=$hdl_type" }
# Read Date
set current_day -format "%d"]
set current_month -format "%m"]
set current_year -format "%y"]
set bool_date " 1 4] 1 4]"
if {$debug} {
puts "Date: $current_day -> "
puts "Date: $current_month -> "
puts "Date: $current_year -> "
puts "Date: $bool_date"
# Open Source File
if } msg] {
puts $msg
exit
# Open Destination file
if } msg] {
puts $msg
exit
# Scan for: DATE_VECTOR_C string & replace
while {!} {
if {>=0} {
if {} {
puts "Replacing :$line"
if {$hdl_type=="VHDL"} {
regexp {(.*?")} $line ignore leftstring
puts "With :$leftstring$bool_date\";"
puts $fpw "$leftstring$bool_date\";"
} else {
regexp {(.*?'b)} $line ignore leftstring
puts "With :$leftstring$bool_date"
puts $fpw "$leftstring$bool_date"
} else {
puts $fpw $line
close $fp
close $fpw
puts "Done.."
