Altera_ForumHonored Contributor15 years agoHow do I customize toolbars in Quartus 10.0 After installing Quartus 10.0, I attempted to modify the toolbars to add some buttons that I use a lot. I tried the usual suspects, i.e., right clicking on the existing tool bar and looking under th...Show More
Altera_ForumHonored Contributor15 years agoi don't think this made it into the new GUI yet. i suspect the document is wrong
Recent DiscussionsFailed to run ip-setup-simulation:Compile option not saved (reversed to default)How to fix Error(23782): Failed to find an expected reportSSLC Login Issue – "You need to enroll" loop after OTP verificationFree Licence for Max+PlusII
