How do i copy macro
Hi I am a student 。
I'm learning Quartus but I have some problems。
I created an A module and used two A modules in the TOP module。
Sorry, so I want to know how to make the same placement and routing of these two modules。
thanks。
My English is not good, so I attach the picture which I drew。
- Nurina
I'm assuming all your modules are in block design files (.bdf) format. If you just add the module A symbol in your top level file then the place and route should not change.
Nurina
- Fenchia_studentM0907
Thanks for your reply。
I design one spi module by using verilog , in my project I need to use two SPI Modules.
I hope the place & route of these two are the same because I hope they have the same timing, but according to my understanding, the bdf file is designed with logic gates, so I think this method maybe not fit my usage situation.
- Nurina
I must apologise, my first reply has a mistake. It's almost impossible to have the same exact place & route for the same two modules in a top level module.
By same timing I'm assuming you're talking about timing closure. You can refer here on what you can do to achieve that:
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an584.pdf
https://www.intel.com/content/dam/www/programmable/us/en/pdfs/literature/an/an903.pdf
https://www.youtube.com/watch?v=HMAqjjCuDEI
Nurina
Thank you very much for taking the time to answer my question.
Sorry, I saw qxp file while reading the information a few days ago. I would like to ask if qxp file can achieve my goal.
- Nurina
No, it wouldn't. I suggest using Timing Analyzer, here you will be using .sdc file to set timing constraints. Since your concern is related to place and route, use post-fit netlist when you create timing netlist.
This video lecture explains how you can do that: https://www.youtube.com/watch?v=79mtPfAm1TA&list=RDCMUC0wEPiFb0J6AZZ3oPXRoRpw&index=3
The following videos are part of the same video lecture series which can be useful for you:
https://www.youtube.com/watch?v=6LYvXTaMto0&list=RDCMUC0wEPiFb0J6AZZ3oPXRoRpw&index=11
https://www.youtube.com/watch?v=ggWxledaBFg&list=RDCMUC0wEPiFb0J6AZZ3oPXRoRpw&index=5
I included the first video lecture on my previous reply.
You might find this timing analyzer tutorial to be useful: https://www.intel.com/content/www/us/en/programmable/documentation/caf1499898833805.html
Nurina
Thank you very much for taking the time to answer me.
I will study the information you gave me, thank you.
- Nurina
Nurina
PS: If you find any comment from the community or Intel Support to be helpful, feel free to give Kudos.
