9 years agoHow do I capture commands generated when using quartus gui
What I want to do is create command line scripts to perform a set of functions that I do using the quartus GUI. I would like to capture the commands being executed through the GUI and use that inf...
9 years agoYes, echoing should be added. It does so with the Assignment Editor, but not the other Quartus stuff.
When you run a compile, the commands get put into the .flow.rpt. That calls each module individually. A full compile that is just like pushing the compile button can be done in a single line: quartus_sh --flow compile <project_name> -c <qsf_name> (The -c <qsf_name> is only necessary if it's different then the qpf name) Another interesting resource for finding commands is typing: quartus_sh --qhelp This launches a GUI with all the commands and options, which is useful for exploring rather than typing help on various commands.
