Rasul_S_Intel
7 years agoHow do I build on top of an IP generated example design?
I am building a project that uses an EMIF to push data from a transceiver to DDR3 memory. I took the following steps and now I am stuck: I generated the EMIF IP I generated the example design for ...
Rasul_S_Intel
7 years agoHi Arslan,
Thanks for the continued help. Yes, I can run the unmodified EMIF example design in Modelsim simulation successfully. Now I want to add IP components to the EMIF example design , which is a quartus project file in the qii directory, and have the new signals show up in the same simulation. The quartus project compiles in quartus, however, when I run the simulation using the process source msim_setup.tcl -> ld_debug -> run -all the new signals from my IP do not show up. This tells me that although the IP has been added to the quartus project, it is not being included in the simulation. Any advice on how to proceed.
Rasul
