Rasul_S_Intel
7 years agoHow do I build on top of an IP generated example design?
I am building a project that uses an EMIF to push data from a transceiver to DDR3 memory. I took the following steps and now I am stuck: I generated the EMIF IP I generated the example design for ...
MuhammadAr_U_Intel
Contributor
7 years agoHi Rasul,
Example design does comes with the testbench and all the files needed to bring up the simulation.
Notice the Figure 8. Simulation Example Design in the document referenced earlier.
Also steps to bring up simulation mentioned in topic "Simulating External Memory Interface IP With ModelSim" of same document.
Are you able to bring up simulation for example design (without any modification) following the instructions mentioned in user guide ?
Arslan
