Rasul_S_Intel
7 years agoHow do I build on top of an IP generated example design?
I am building a project that uses an EMIF to push data from a transceiver to DDR3 memory. I took the following steps and now I am stuck: I generated the EMIF IP I generated the example design for ...
Rasul_S_Intel
7 years agoHi Arslan,
Thanks for the reply. So if I took the hardware implementation from the qii folder and added my components to it I would need to write a testbench for it and pull in the ip components manually to the project in order to run in Modelsim? The main point of confusion is that I don't understand modelsims mechanism for running the simulation without a testbench from the sim folder.
Rasul
